Old Mar 2, 2014 | 08:50 PM
05Rd5tr's Avatar
05Rd5tr
Default Top problem help please !!!
Hello to all !! I have been a member for quite some time, although i don't post often but need some help DESPERATELY !!! My wife owns a 05 Roadster that I purchased for her approx a year and a half ago. She has LOVED the car w/ the exception of the ongoing top problems. Now it is at the point that she almost hates it !! Here is where it all started: we purchased the car used (low mileage) and had ZERO problems until the rear glass separated. No biggie right ??!! Top recall ?? Yup, it applied. After that , the top leaked like CRAZY!! Mind you that I had a thousand dollars worth of seals installed because that was the only way that they said that they would warranty it against leaks during the top replacement. After FOUR repeat trips back because it would leak all over when it rained, they finally stopped the leak. After the third visit we started having issues w/ the top going up after it was put down. After the fourth repair that SEEMED to stop. UNTIL this weekend. Nice sunny Florida day right ? Top down, won't go back up. Each time the same issue, no matter which way you toggle the switch,the top goes down. Even if you use the tool to release the top and raise it partially , flip the switch and the top goes down. Any ideas? Could it be as simple as a switch issue or possibly a module issue ? Any and all help would be GREATLY appreciated !!!!
