Old Mar 3, 2014 | 05:26 AM
simkard's Avatar
simkard
Default CAN BUS - Learning ...
Hi all,
I'm actually going to work with th CAN BUS which seems to be present in our Crossfires.
I will use an Arduino with the CAN-BUS Shield from Sparkfun that you can find informations here : https://www.sparkfun.com/products/10039
Does someone here already tried to communicate with the CAN BUS ?
For the first times, i will try to get these values in realtime :
- RPM
- Engine Load
- Coolant Temperature
- Oil Temperature
- Air Intake Temperature
Later, i will try to capture commands like window buttons, remote key fob button press for adding options like lowering the window while staying pressed on the OPEN button on the key fob.
If you want to share your knowledge, let's go !
Thanks
