Re: Need help car not accelerating
I just replaced pedal and drove away, no issues showed up. You will need to use a magnet to get the washer off the stud once nut is removed or it will never come out. Once you do that, lift up slightly and pull it out backwards. Pull hard to get the upper friction fastener to let go. The stud slides out through a slot in back of recess where nut goes.
