Old Mar 9, 2014 | 04:05 PM
  #86 (permalink)
g3air's Avatar
g3air
Default Problem
All went well (I thought) with the pump etc, but no joy on trying it out. The windows went down, but then there was hydraulic pump noise I associated with the bow latch operating and then no further progress was noted. If anything, I would say the latch was trying to close further rather than open, but it is not possible to observe the latch when it is operating. I re-verified that I had connected the hydraulic lines to the proper fittings on that latch and loosened and re-tightened its mounting and tried once more with the same result. I turned all off and manually operated the top, but I forgot to relieve the hydraulic pressure, and that is where I believe I snapped the cable which operates the left side small rotating wing on the tonneau cover.
I guess this may be one reason why it's smart to pay the high prices of dealer service. I am not happpy with myself at the moment. I will review all my work again tomorrow. I am a sad panda. I just don't feel up to posting pictures right now.
I could not find out anything in the service manual about the cable that I destroyed. It is not the top cover cable. Any hints would be appreciated as to where I could look.
EDIT 12 March: it turns out the damage to the cable was not so awful, thank goodness...
