Old Mar 12, 2014 | 08:41 PM
James1549
Default Re: Battery drain, need help.
Originally Posted by Dnivek
Update: I checked for drains by monitoring current draw, then pulled fuses of suspected problems. The second fuse I pulled( cigar lighter ) was the issue. There must be leak to ground small enough not to blow the fuse on that line. After leaving that fuse out all day today, no issues. I'll monitor it for the next few days to be sure that was it. I suspect I'll be needing a new lighter socket, know of a good source?
I thought that circuit was switched with ignition? My lighter don't work with the ignition off. It works well for me because it will auto turn off my GPS.
