Old Mar 12, 2014 | 10:54 PM
onehundred80
Default Re: Battery drain, need help.
Originally Posted by Dnivek
just went out to the garage to put the ammeter across that pulled fuse... front and rear flashers were on. If I wouldn't have went out there it would have been dead again by morning. I did lock the doors with the remote when I parked the car tonight. What the heck is causing the flashers to activate? The alarm getting set off...but by what...? Clearly the cigar lighter is not the issue.
Look for water damage in the pump/security module under the foam behind the passenger in the trunk. If you find water you have found your problem.
