Need your help! Brake lights not working.
Mar 13, 2014 | 09:37 PM
permalink
onehundred80
Apr 2006
25,432
651
Ontario
Re: Need your help! Brake lights not working.
Quote:
Johnny24
Onehundred,
I just went out to the car to check and see if i could hear the click and sure enough it does click when i press it down.
What does this mean?
Thank you again dude.
I am getting out of my depth here. The relay is working so power is going to the light switch. The light switch is referred to as the Illumination Control Module in the Service manual. Presumably the power is not coming out of the switch.
Have you or anyone else been into the back of the switch area? It could be possible that the plug that goes from the relay to the light switch is loose. I have seen a situation where the lights went out suddenly when a plug came loose as it had not caught on the catch on the switch.
There are four plugs that plug into the light switch and you should check that they are all tight.
The ABS system is somehow involved with this relay, brake switch and light switch.
The power comes from and returns back through the light switch on its way to the brake lights.
Look at 8W-51-3 in the service manual for a circuit diagram.
onehundred80
View Public Profile
Send a private message to onehundred80
Find all posts by onehundred80
