Old Mar 15, 2014 | 03:12 AM
ichon's Avatar
ichon
Default Re: Parts you'll need soon for sale
BLOWOUT SALE:
(1) Slightly Used Differential (Retail:$759) $399.00
(5) New Starter Relay Modules (Retail:$465) $215.00 each
(1) Slightly Used Supercharger Throttle Body Unit (Retail:$1235) $400.00
(1) Slightly Used Electronic Oil Sending Unit Module (Retail:$795) $250.00
(1) New Convertible Top Micro Roof Switch and Latch (Retail:$1175) $400.00
(4) Slightly Used Intake EGR Valves (Retail:$188) $75.00 each
(1) New Set of Yellow/Front Side Markers (Retail:$78) $45
(1) Slightly Used Homelink Module (Retail:$138) $50.00
(1) Slightly Used Relay Module Radiator Fan Castor (Retail:$375) $85.00
(1) Slightly Used Oxygen Sensor (Retail:$135) $60.00
(1) Slightly Used Ignition Starter Switch (Retail:$52) $29.00
(1) Slightly Used Alarm Siren (Retail:$150) $75.00
(2) SRT6 OEM Front Rotors - $195.00 - Gently Used
(2) SRT6 OEM Rear Rotors - $185.00 - Gently Used
(4) SRT6 OEM Brake Pads - Front and Rear - $55.00 - Gently Used
(2) SRT6 OEM Valve Covers - $150.00 - Gently Used (-10k)
(2) SRT6 OEM Valve Gaskets - $15.00 (Used)
(2) "SRT Design" Emblem(s) - $30.00/each - New
(2) 15mm Hub-Centric Spacers - $60.00
(10) 15mm Spacers Lugs/Studs - $65.00
(1) SRT6 OEM Navigation CD (North America) - $45.00
(20) 1/2 - 2 Studs with Key - $38.00
(2) SRT6 OEM Front Shocks - $65.00
(2) SRT6 OEM Rear Shocks - $65.00
(1) SRT6 OEM Bosch InterCooler Pump (USED) - $30.00
(2) SRT6-N/A OEM Bezel Door Lock Trim #A21072302249B51 - $35.00/each
(2) SRT6 OEM Door Tweeters - $20.00
(1) Chrysler Euro Gas Tax Medallion - $15.00
(1) Chrysler Illuminated Door Sills Relay Module - $55.00
(1) K&N High Flow Air Filter #RB-0910 - $25.00
(2) K&N High Flow Air Filters #33-2290 - $15.00/EACH
(1) Wix Oil Filter #57078 $15.00
(1) Needswings/Mann Oil Filter - $15.00
(6 Qts) Castrol Edge Titanium 5W-30 Oil - $45.00
(2) SRT6 OEM Front Springs - $105.00
(2) SRT6 OEM Rear Springs - $110.00
(2) SRT6 OEM Air Filters - $30.00 (Used) (each)
(1) SRT6 OEM Driver Side A-Pillar - $65.00
(2) Rotalla 225/40R18 92W XL F107 Tires - $255.00
(1) Michelin 255/35ZR19 96Y (worn-good for drag racing only) - $45.00
(1) SRT6 OEM Oil Cap - $20.00 (Used)
(2) SRT6 OEM Side View Mirror Inserts - $20.00
(5) SRT6 OEM Valve Stems w/Chrome Caps - $20.00
(1) Mercedes Benz Chrome Blue/Gold/White License Plate - $25.00
(1) Burago '54 Mercedes Benz Black SL300 1:24 - $15.00 (Loose)
(1) Maisto Mercedes Benz Silver Vision SLR 1:18 - $15.00 (Loose)
(4) SRT6 OEM Front Light Bulbs - $20.00 (Used/Functioning)
(1) Chrysler Chrome Compact Mirror - $25.00
(1) SRT6 OEM Floor Outlet Vent #A1708300266 (R) - $35.00
(1) SRT6 OEM Floor Outlet Vent #A1708300166 (L) - $35.00
(2) Taillights (Used/Tinted/RHS has small center crack) - $165.00/each
PRICES INCLUDE S/H IN CONTINENTAL UNITED STATES. LMK
