IBLUBYU
Larry .... Don't know if it will help, but if you have another key fob that works, I would try to dismantle the "wet" fob the best you can without physically destroying it, and then wet it again with water to flush any detergent, and then "pickle" it in WD-40. As you know WD-40 is water displacement stuff. Dry it and reassemble, then see if you have re-incarnated it. Just sayin .....Good Luck
I can give it a try as I won't be out any more than I am right now. Thanks Howard
