Old Mar 16, 2014 | 06:48 PM
srtmodder's Avatar
srtmodder
Default Re: Changing the interior this week!
Thanks everyone!
RedDog- A friend of mine already bought them off of me. Sorry.
JEFASOLD- I'd recommend just looking on dipyourcar.com they have a bunch of colors to chose from. I just knew that black would work most likely pretty good and I like the contrast from the headliner.
caseycowen5- Yes, removed the rear hatch pieces. Once you pop off the circle center piece in the handle area there will be one bolt to remove on that part. Once having removed the bolt just slowly pull it evenly off from all sides bit by bit. Having done that the second piece will have two bolts to remove and then slowly pull it off also. Pretty simple just not rough with movements since they are plastic pieces still.
TommyT- southwest side of Houston. You?
Again, thank you I was really glad to get it done.
