Originally Posted by xfire1
has anyone noticed at times the rear brake (mine is at the passenger rear) clunks when at a stop. it happens when the brake is depressed and when i go to release it. happening mostly on rainy or very humid days...
j
Check that your rear calipers are bolted down tightly and that the pads are seated correctly. Also inspect the control arm, sway bar and bushings. sounds like you may have a loose part that is being torqued when the brakes are applied.
My guess is the caliper...
