Old Mar 18, 2014 | 02:29 PM
JPT's Avatar
JPT
Default Re: HELP! Reverse Lights Wired to Radio Harness?
So If I tap into the wire that 16 is pointing to I should be good? There were two wires that were plugged into the radio harnness that needed to be cut to fix the phone/mute issue for the Bluapunkt, do I need to tap both of them into this switched wire, or just one? What do you think?
Thank you so much, I think this will work. I can test one or both and see what happens. At least I have something to try.
Thanks man!!!
JPT
