Old Mar 20, 2014 | 12:48 AM
syfi's Avatar
syfi
Default Re: Going to purchase a sub
Going by that list will still involve some kind of modification of the sub cage. I don't think we've ever found a direct "plug & play" woofer simply because the magnet on the OEM subs are so narrow/round, unlike any other sub. You usually have to do some dremel work on the cage to make room for the larger magnets on all the aftermarkets. And I'm not sure if those stating no modification/direct fit are actual dual voice coil 4 ohm rated, that is if you're still running the OEM amp.
Geez....now I'm confused!
