2004 Crossfire/Charging
Mar 21, 2014 | 12:11 PM
27
permalink
onehundred80
Apr 2006
25,432
651
Ontario
Re: 2004 Crossfire/Charging
Quote:
pizzaguy
Regulation of the alternator output is internal to the alternator - there is no separate regulator.
That is not quite true. The regulator is bolted onto the back of the alternator or generator as it is called in the Service Manual.
GENERATOR
DESCRIPTION
The generator (1) is belt-driven by the engine using a serpentine
type accessory drive belt (2). It is serviced only as a complete
assembly. If the generator fails for any reason, the entire
assembly must be replaced. The only component that is
replaceable is the voltage regulator.
onehundred80
View Public Profile
Send a private message to onehundred80
Find all posts by onehundred80
