Old May 4, 2006 | 04:54 PM
xfire1's Avatar
xfire1
Default Re: Diy Oil Change - Extreme Caution
Originally Posted by danimal
... dropping a cap ring there would be much less catastrophic than down into the oil pan, and much easier to retrieve.
So, I have learned a couple of things from this and thought I would share them. First, only put oil in where it is supposed to be. Use a funnel, or in lieu of that, make sure to remove the cap ring as well. Count your bottles, caps, AND RINGS when you are cleaning up. If this saves one engine...it’s worth it.
Did you see where the guy dropped a rag into oil filler mouth, didn't know and started up the MB!!!
Funny but sad!!!
