Re: Kenwood KDC-BT955HD (finally installed new headunit!)
hokkabaz
I havent seen what the stock amp look like, if there is a way to separate the subs from the doors without adding an additional amp, I would do that. And a new HU with little bit more power, thn I will be done with the audio mods.
Search for 4 channel amp, there is a thread explaining how to separate the front and rear channels. Basically you just have to run wires from your pre outs on the new head unit to the amp. Very easy if you have done any stereo installs in the past. All diagrams and info you will need is on the forums. You will have to make sure your pre outs are 4v+ if you really want to turn up the volume. My alpine only has 2v and I wish it would go just a little louder but it is still acceptable after playing with crossover settings and such.
Adrian_X
Someone else might chime in on this one, but doesn't our stock amp have RCA inputs?
No RCAs
