A newb question from a veteran...
Mar 30, 2014 | 09:36 AM
permalink
onehundred80
Apr 2006
25,432
651
Ontario
Re: A newb question from a veteran...
Quote:
blue road runner
A bad speed wheel sensor caused similar problems in my na roadster.
The problem has showed up here before and I just had the same problem with a sensor in my rear driver side on my 300. The code said it was the front driver sensor, a new sensor there solved nothing and the garage I then took it to said it was the rear sensor and it was.
This problem with the code indicating the wrong sensor position has showed up on this Crossfire forum a while back as well.
My scanner did not show the error code, but the self diagnostics on my 300 found the code,
U1417 which is ' Left front wheel sensor fault'. This of course turned out to be the rear sensor.
onehundred80
View Public Profile
Send a private message to onehundred80
Find all posts by onehundred80
