Re: Do I Need Spacers
Nice wheels! The rears will "most likely" rub the inner fender wells aggressively. Put them on and see. Going around the block won't hurt anything even with a bad rub. I see a 12mm or 15mm spacer in your near future which means you'll need longer lug bolts too. The perfect offset will depend on how wide the rear tires are. If stock both 12mm and 15mm will work.
You definitely can't have a rub at speed cornering at the Dragon. Rubbing has the same affect as applying just the rear brakes. The rear of the car will snap loose on you.
Les
