robby363
Do you know why they can't change it? If the bolt that holds the connector plug to the valve body plate won't come out (just spins) than you will have to replace the valve body plate also.
This issued happended with my connector. Took it to 2 places and it just spun and couldn't be extracted without dropping the pan and breaking it off the internals / valve body plate. Luckily, mine was still under warranty -- otherswise it was a $2500 dollar job. HOWEVER, you can find the connector plate, connector, valvebody unit on line a lot cheaper and then have someone install it. Also, the connector plate and Valvebody are actually 2 separate pieces, not ONE. They don't have to break both so don't let them tell you it's one piece. Good luck.
