Old Apr 1, 2014 | 06:25 PM
RED DOG's Avatar
RED DOG
Default Transmission cooler lines hooked to lower radiator area?
I have to admit I'm a bit more experienced working from above the car than from underneath it. I've spent a couple hours searching the forum and can't seem to find what I need to know. I need some advice / confirmation on where the transmission cooling lines connect to the radiator. I THINK I see two lines . . . one connected to each side of the lower radiator area. I presume one is the incoming transmission fluid and one is the outgoing transmission fluid. Which side of the car is the incoming fluid line? Does anyone have a picture so I can confirm that I'm actually looking at the correct transmission fluid lines hooking up into and out of the radiator? Thanks in advance for sharing your expertise . . .
