Old Apr 2, 2014 | 03:55 PM
shaag78749's Avatar
shaag78749
Default Re: 18x9 Mercedes Replica Rims
Yes is the short answer. The long answer: I'm running the 18x9 rim with a 275/40/18 Nitto tire in back, which is just a little taller than the stock 255/35/19 and 20mm wider. I run a 10mm spacer on the 32mm offset rim, but I don't believe that it's necessary. SCCA allows running a 1 inch diameter smaller or larger rim in Solo Street classes, and that's why I got these rims. I wanted to lose some weight, but these rims are heavy (about 32 lbs each), which means the tire and rim weigh 60.2 pounds. Hope that helps.
