Old Apr 7, 2014 | 08:07 PM
TopHydraulics's Avatar
TopHydraulics
Sponsor
Default Re: Top Hydraulic Fluid leak
cuziamninja,
welcome to the forum! You are having a leak on the bottom of the right main lift cylinder p/n 5170015AA. Your Crossfire has seven hydraulic cylinders, and they will all leak with time. They typically leak first on the bottom, and those leaks only get bigger. You must take care of it. Unfortunately, the cylinders were designed with seals that limit the life span to some ten years. The good news is, you can have the cylinder(s) rebuilt for a fraction of what the cylinder cost new when they were still available. Top Hydraulics upgrades all seven seals inside the cylinder, and makes it better than a brand new one that way. You may want to browse through the following, awesome thread by g3air with loads of photos and details: https://www.crossfireforum.org/forum...p-problem.html
Klaus
Rebuild/Upgrade Service for Chrysler Crossfire Roadster Hydraulic Cylinders - Top Hydraulics, Inc
Top Hydraulics | Rebuilt and Upgraded Convertible Top Cylinders, Pumps, Hydraulic Lines - Top Hydraulics, Inc
