Old Apr 10, 2014 | 11:29 AM
IBLUBYU's Avatar
IBLUBYU
Default Re: CPS with no retaining screw?
Try this .... if you can touch the screw with a finger, take a coat hanger and see if it moves a little and is not wedged in. If it moves slightly,thats good, put some clear silicone caulk on your "best finger" and touch the screw with it, and see if the screw lifts out, being "stuck" to your finger. If the space limits the use of your hand/finger, put some of the caulk on the end of a coat hanger and try to fish it out with that. Hopefully the screw will stick on the caulk when you withdraw. Just sayin...... The danger is, if with all your tries to get it out, you have wedged it in so tight, that this won't work..... good luck.
