Old Apr 11, 2014 | 12:19 AM
amx1397
Default Re: 225/45-18 & 255/40-19
Originally Posted by mikep330
I plan on putting 225/45R18 Michelin Primacy on stock 18 rims for all four tires with out any offsets for the rear. Will I run into any problems other then the rear looking funny?
stock height is 25.1" front
stock height is 26.0"rear
the 225/45-18 are 26.0" tall and will rub on the front. ,,,,they would work fine on the rear
the 255/40-19 are 27" tall but will work on the rear,,check if the tire rubs the front lower of the finder ,on the ground and jacked up if yes when jacked up you may not get that tire back on.(it will come off fine.
goof luck jim
225/40-18 at 25.1 tall would work just fine on the front
245/40-19 at 26.7 tall would work just fine on the rear
