Re: NA fueling...
The pump pressure with the OEM is @56-60 pounds, PLENTY for the N/A engine.
The reason for the 55 upgrade on the 6's is that when boost is increased, you eventually reach the area where the AFR's start to go to the lean side, then you add bigger injectors which in turn need the bigger pump. ( that's from what I read on the forum, I don't have an SRT6 )
