Old Apr 18, 2014 | 02:03 PM
RL67037's Avatar
RL67037
Default Re: Service indicator on ODO screen?
Just a note on the FSS - from what I've read here and what I've seen on my car, the FSS does not simply count off 7K miles. It monitors several sensors on the car and adjusts the mileage between changes accordingly. I think if you hit the button within one second of turning the key to the "On" (not Start) position, you will see the remaining miles the FSS is showing. Depending on how you drive your car, if you check it again in, say, 100 miles, it probably won't have changed 100 miles - it might be more or it might be less. That said, I'm with 180 on this - I wouldn't run my car to the limit of the FSS - change the oil a bit early and all should be well.
