Silverarrow
I'm getting the CEL P1107 saying that the map sensor circuit voltage to low. Does somebody else having this issue? I have read in different forums about bad ground leading to that the 5v feeding voltage to the map sensor is below 4.75 volt. I will try to measure the feeding current this weekend.
Could it be that the Zeitronix connection is leading to a voltage drop? I have actually connected the zeitronix ground to the ground on the ECU. Maybe this is wrong.
I will try to disconnect the Zeitronix and check if the CEL goes away.
Need all the help I can get
No CELs for me, I have attributed the early "low" readings to belt slip. Aluminum makes a lousy surface for traction, given the low coefficient of friction (relative to steel). Now that I have some miles on the pulley, the slip seems to be less than before and the car will absolutely put you back in the seat at WOT
