JHM2K
No CELs for me, I have attributed the early "low" readings to belt slip. Aluminum makes a lousy surface for traction, given the low coefficient of friction (relative to steel). Now that I have some miles on the pulley, the slip seems to be less than before and the car will absolutely put you back in the seat at WOT
My readings are about 19.8PSI which is actually ok. But the CEL P1107 that I'm getting doesn't seem to come from a boost leak it seems that the feed voltage to the map sensor is to low. I'm wondering if this could be because of the Zeitronix with all the sensors that are connected to the same ground wiring on the ECU, hmmmm. Just a wild guess, that is why I would like to try to disconnect the Zeitronix to start with then do a diagnostic measurement on the map sensor according to the Crossfire manual.
