Old Apr 23, 2014 | 11:04 AM
JHM2K's Avatar
JHM2K
Default Re: Vacuum and boost leak, EC 61mm pulley
Originally Posted by Silverarrow
My readings are about 19.8PSI which is actually ok. But the CEL P1107 that I'm getting doesn't seem to come from a boost leak it seems that the feed voltage to the map sensor is to low. I'm wondering if this could be because of the Zeitronix with all the sensors that are connected to the same ground wiring on the ECU, hmmmm. Just a wild guess, that is why I would like to try to disconnect the Zeitronix to start with then do a diagnostic measurement on the map sensor according to the Crossfire manual.
Makes total sense... wires are wires, at the end of the day. If you load too many things on a small gauge wire like that, it can affect the items at the end of it (MAP sensor, in this case).
