Old Apr 24, 2014 | 10:58 PM
onehundred80
Default Re: Just purchased SRT-6, new to forum and performance questions
Originally Posted by Codyktt
I just purchased a 2005 SRT-6 Coupe, 68K miles. Few issues when I had an initial inspection, bad tread patterns (needs alignment), no problem. Steering stabilizer was leaking ($30 ebay).
No active or any serious past codes saved. Previous owner didn't know how to install HID's, so I'm picking up stock bulbs. Driver valve cover leaking, fixing in a few days.
Driving home from Pensacola to Navarre went okay, the car hadn't been run in a month, I let it warm up, drove to the nearest gas station and filled up premium with injector cleaner. Start driving home, everything is okay, I can feel the tires being bald on the inside. Performance is good, however half the time while driving at highway speed, it doesn't seem the supercharger is doing much when trying to accelerate. From a standstill it'll wind up and speed away as expected, yet sometimes nothing at all will happen when floored. Any advice for a new crossfire owner?
Any help would be appreciated, I will be contributing to this forum for the next few years.
Thank you in advance,
Cody
The IC pump has failed, it is the #1 reason the SC does not work when the coolant gets too hot.
Read these posts found when using 'IC pump' in the Google search function.
CLICK
PS
Welcome.
