Stop/Brake Light
Hi
I noticed well I did'nt loads of drivers have told me and the interior warning light tells me that make brake light works intermittently.
This morning I took a look, and found that either the bulb carrier is not good or the bulb "lugs" are not quite long enough to make sure the bulb stays in place.
I tried several times to re fit bulb put even when correctly fitted you could pull the bulb out without turning to the release area?
Anyone found this happening?
