Headlight wiring question. Please help
Hi guys,
I am in the process of updating my baby's headlights to HID. I'm stuck and need advice. I am referring to the positive and negative leads from the harness that connects directly to the headlight bulbs. There are two prongs, one has two wires and the other has one wire. Which is the positive and which is the negative lead?I AM REFERING TO THE FACTORY BULB CONNECTOR- SET OF WIRES. I'm not sure but I am thinking the one with the two wires is the positive. Can anyone help? Thank you!!!! I do not have a voltage tester...
Reason: ommitted important info.
