Originally Posted by CrossyLover
Guys, I just went out to my car and pulled up the boot... There is alike a cone shaped dealy directly connecting the boot and **** ya know? Do you just unscrew that counter clockwise?
yup; that collar unscrews and the **** pulls off (its on there good... but give her a wiggle and a pull and it should break loose).
- pop shift base off and remove window switches
- unscrew collar and remove old shift ****
- lay new collar around shifter
- set base back down (but not popped back into console)
- insert correct rubber adapter (smallest one that will fit)
- use set screws to lock down new shift **** on shaft (don't forget silicone)
- pull boot up around new shift **** and screw collar on (a little tough... you'll see what i mean)
- reattach window switches and set base into console
