Thread: Shift Knobs
Old May 10, 2006 | 08:08 AM
former NXMX5's Avatar
former NXMX5
Default Re: Shift *****
Originally Posted by former NXMX5
yup; that collar unscrews and the **** pulls off (its on there good... but give her a wiggle and a pull and it should break loose).
- pop shift base off and remove window switches
- unscrew collar and remove old shift ****
- lay new collar around shifter
- set base back down (but not popped back into console)
- insert correct rubber adapter (smallest one that will fit)
- use set screws to lock down new shift **** on shaft (don't forget silicone)
- pull boot up around new shift **** and screw collar on (a little tough... you'll see what i mean)
- reattach window switches and set base into console
good luck!
