Old May 5, 2014 | 11:59 PM
Cedar11's Avatar
Cedar11
Default Re: Cold start taking too long - no codes
Originally Posted by dinasrt
A possibility is the fuel pump check valve going bad, not holding any pressure to the rail would cause a longer wait time to fire up the injectors. Try turning the key to the on position(no cranking)for 5 sec.'s, before trying to crank/fire it up. Does that help? If that doesn't help, then the problem is something else. Good luck.
I will try this tomorrow, thanks.
Fuel related is my guess, the system is not holding or giving the correct fuel pressure.
Pump or filter issue.
Thanks
