JHM2K
Josh,
I was referring to this thread below for the removal:
https://www.crossfireforum.org/forum...-no-start.html
And was curious if there's a specific joint that I should be looking for? Would it be the typical failure points that would cause the shut-down?
Thanks man,
Honestly, I think some of the joints that looked fine on mine were bad, that's why I went over every single one with fresh solder. If the joints for the fuel pump relay are bad, that could be your issue right there. I wouldnt even bother checking the joints out, just run fresh over all of them.
