Old May 9, 2014 | 05:00 PM
onehundred80
Default Re: CPS and Fuel Pump
Originally Posted by JD-04-Coupe
Will a bad CPS stop the fuel pump from working? The fuel pump rarely activates in the ON position, and the car does not start. When the pump activates, the car starts, but within 10 seconds, dies. When attempting a re-start, there is no fuel pump sound, and it wont start. I have a new battery, re-soldered the RCM, installed a new fuel filter.
You are probably making the wrong assumptions here, if the fuel system is pressurized then you will not hear the pump until some gas has been used. So a restart will not require the pump to come on, or if it does the sound will be hidden by the starter noise.The CPS is not a contributing factor in the fuel pump operation directly.
