Re: CPS and Fuel Pump
No fuel from valve. And then, no sound from fuel pump. Even though when its working, I can hear the pump from the drivers seat, I had a helper turn the ignition on while I listened from underneath.
I will be checking voltage, next.
First at the fuel pump; then at the RCM.
Where is the best spot on the fuel relay in the RCM to check voltage?
