Old May 9, 2014 | 08:04 PM
JD-04-Coupe's Avatar
JD-04-Coupe
Default Re: CPS and Fuel Pump
While looking for the correct pin in the service manual, I found the following:
"OPERATION
The fuel pump relay supplies battery voltage to the fuel pump. The fuel pump relay power circuit contains a fuse.
The fuse is located in the relay control module. Refer to the Wiring Diagrams for circuit information.
The PCM controls the fuel pump relay by switching the ground path for the coil side of the relay on and off. The
PCM turns the ground path off when the ignition switch is in the Off position. When the ignition switch is in the On
position, the PCM energizes the fuel pump. If the crankshaft position sensor does not detect engine rotation, the
PCM de-energizes the relay.
