Originally Posted by Yiger
Is there anyway to install these in the base coupe (since the base doesn't have power seats)?
you'll have to pull your stock seats and look for the factory wiring harness that hooks up to the power seats.
if the harness is there (tucked under the carpeting)... you should be good to go.
you can also see if there is an allocated power seat fuse located in the main engine fuse box. but it may be shared with others components as well.
