Old May 11, 2014 | 08:30 AM
onehundred80
Default Re: Central locking dont work after dead battery
Originally Posted by Pontus1991
Hi, last friday i forgot the lights on and my battery was drained, i cant open the doors with the key for some reason so i had to unscrew the thing holding the bonnet in order to take the battery out and recharge it.
Today i went back to put the battery in the car again and the lights went on so i know the battery is charged, but i still cant get into the car because now nothing happens when i click any button on the key, i checked the central locking fuse under the bonnet and its ok.
Any ideas?
I know you said you used the key, but I have to ask if you actually tried the key in the lock. It has happened that people forgot what a key really was.
If people read both posts then what you said here could be a bit ambiguous.
This is a post I did some time back. Click
(This above was repeated by another member here.)
So there is another problem if the key does not open the lock.
