Old May 11, 2014 | 08:55 AM
onehundred80
Default Re: Central locking dont work after dead battery
Originally Posted by Pontus1991
Yes I tried the key in the door, there's no resistance when i try to turn the key and nothing happens
My guess is the unlock mechanism is not attached to the lock cylinder.
Also, when the battery died the coded signal from the fob to the SKREEM was forgotten and the fob needs to be paired with the SKREEM again. When you can get in the car that is.
Your local automobile association will have people that can open your door without a key, or you could ask some gang members hanging on a street corner to do the job for you.
Mine is OK but I think others here should disconnect the fuse (#25) to the security module and see if their key unlocks the drivers door only. Not removing the fuse will trigger the pump to unlock all the doors etc and you will have proved nothing.
