Old May 14, 2014 | 04:47 PM
YraggarY's Avatar
YraggarY
Default Re: Mystery creak, and associated sanity loss! Help? :D
Are the points where the rear stabilizer bar clamps attach to the floor being torn away from the floor pan?
I got the time to jack her up and put her on stands today and checked absolutely everything. The points where the stabiliser bar clamps attach to the floor are very corroded, but from what I can see there aren't any cracks / tears / movement. It's hard to get a good look at the backs of them but I'll remove the interior trim at the weekend and see if there's any sign of that from the inside. The actual stabiliser bar itself is incredibly corroded at one point in the middle near the diff. The black coating seems to be "split", exposing the bar which is rusted to hell. I'm a little concerned about it so I'll upload some pics later when I find my phone cable, any advice on the corrosion would be appreciated!
Originally Posted by DRUMMY
OK So when it gets warm the problem is there.
therefore you have to look for parts that that heat up.
Exhaust hangers,exhaust joints,disc backing plate rubbing,
My guess is that the handbrake mechanisum where it goes into the drum.
take drum off remove brake dust etc a little grease on joints,you have brake shoes in the rear drum for handbrake.
When you first stop to park up can you still get sound when you push down on rear if you leave handrake off.
The creak started the second I moved the car this morning, so it's happening when cold too. Checked exhaust hangers, joints, rotors, everything just in case. I couldn't replicate the sound at all by attempting to move any component and everything was solid; the fact that I couldn't replicate it while the car was in the air is making my best guess either shocks as Bill F said, or springs (possibly the isolator pad).
Originally Posted by Speedy4x4
Mine started the squeak just over a week ago. Driving me NUTTS also.
Last weekend I put new cross drilled rotors and ceramic pads all the way around and used lithium grease sprayed on all the bushings. Still there. I am going to change all of the urethane bushings on and around the rear end. Just need to find a good quality set.
I've lubed up every bushing and moving component I could find, and I'm about to take her out to see if the noise is still there. Unfortunately with this approach if the noise is gone I won't know exactly what it was but I'll be looking into replacing all of the bushings regardless. If you find a good set please point me in its direction.
Originally Posted by Sandy
Comic Relief:
When I was 18, in 1968, the lady across the street had a Cadillac with a rattle in the door. She kept taking it in, kept checking the window and all parts associated with the door. Finally, the Cadillac dealer had had enough, and removed the entire door. They tore the door down completely and in the bottom of the door was a loose coke bottle with a note in it: The note said "So you finally found the source of the rattle!"
I once heard a joke about this, but this happened in Deerfield Beach, Florida.
Haha, that's horrible! I've checked for coke bottles around the rear suspension though, no joy.
Originally Posted by WHski
Mine too has started the creaky noise. 98,000 mi., but I am still looking for it also. Some days are worse than others, though usually it is quiet in the rain.
The creak on mine is constant (I have no good days!! ) and unaffected by the weather. Other members will correct me if I'm wrong but I seem to recall reading somewhere that leaking shocks can often give that symptom, creaky/squeaky when dry but quiet in the rain.
