Old May 18, 2014 | 06:41 PM
EtherOxide's Avatar
EtherOxide
Default
Originally Posted by RED DOG
Thinking about this a little more, it also could be that you need a different shim thickness. When the Code3 pulley was installed were the same shims installed that were on the stock pulley? As the newly installed pulley "seats in", the clutch may have started rubbing slightly when disengaged causing that squealing sound. Maybe another forum member can chime in on the likelyhood of problem being related to the shim thickness. The more I think about it I'm believing that could be your problem. If you have another shim ring you might try installing it to provide just a bit more shim thickness creating additional clearance between the clutch faces when the clutch is disengaged.
You were right. I think the shim thickness has slightly decreased since the pulley was changed. The clutch and pulley seem damage free. I have a number at eurocharged that can send replacements. I'll let you know if this solves the problem. Thanks again!
