Old May 20, 2014 | 12:08 PM
07Limited's Avatar
07Limited
Default Oil leak leads to new problem
OK, first off I'll admit that this has me feeling like a total dumbass right now. 30+ years in machining and engineering and I can't figure out an oil cap.....
So I have the common oil leak on the drivers side valve cover. It appears to be coming from the inspection cover on top of the valve cover. That's been well documented here and I'm sure that's the problem. But before I did that I wanted to replace the gaskets on the oil filler cap and the riser tube just in case.
The filler cap comes off just like normal so I start to twist the riser tube in the same direction as the cap to remove it. There's a little resistance so I apply more muscle. Then I hear a cracking plastic sound and I stop. The riser tube will move back and forth about 45 degrees or so then stops dead.
Before I do some serious damage and have to buy more parts, someone clue me in as to why I'm having this trouble. I've looked under the riser tube and I do not see a release or anything but I do see the tab that stops it from turning counterclockwise.
