pizzaguy
Yea, the hydraulic system is self-correcting/calibrating/etc. No issue there.
I put mine up and down manually from time to time and even leave it halfway up to clean the rear window or, one time, to work on the fuel level sensor in the gas tank!
I've seen the "top open" switch over the passenger's head fail a time or two. They often fall apart - you can look at them and tell they are bad!
just an update waiting on the divider sensor/switch to come which should be today or tomorrow then I am going to change that out and see what happens...if still nothing then its to the sensor/switch over the passengers head...then if that doesn't work then it is to the trunk closed sensor and then if that doesn't work it is going to be driven off of a dock and into the ocean to create an artificial reef for the fishies...lol
