Thread: Service Code?
Old May 22, 2014 | 07:32 PM
Valk
Default Re: Service Code?
To reset the miles to next service back to 7000 and clear the wrenches follow this procedure exactly as it says
You might need to try it a couple of times to get it to reset but it will
RESETTING THE FSS MAINTENANCE INDICATOR AFTER AN OIL CHANGE / Service etc.
1) Move the ignition switch to the “RUN” position
2) Within 4 seconds of moving the ignition switch into the
“RUN” position, press the reset button for the trip odometer
twice within one second The display for the FSS service
request is activated for 10 seconds
3) During the 10 seconds the FSS service request is displayed,
move the ignition switch to the “OFF” position
The FSS service request will continue to be displayed
4) Press the reset button for the trip odometer and
hold
5) Move the ignition switch to the “RUN” position
6) Continue to press and hold the reset button for the trip
odometer (about 10 seconds) until the audible signal
sounds and the new start distance appears in the display
The tool symbol should disappear at this time
