Re: top wont go down
ok finished putting the switch in...just for future reference for anyone who has to do this the nut size on the 2 posts for the divider switch is 10mm...you will need a 10mm crescent wrench for one nut and a regular long 10mm socket that will work on the other nut....switch seems to be working put the top up and down about ten times in a row but it seems that I have a loose wire going into the console top up/down switch because after about the 10th time top was down and locked in trunk then bam top wouldn't come up kept trying windows would come up but that was it...then held bottom of switch where wires go into the switch and then it worked...seems like a loose wire since that console switch is new....thank god I got it to go up and this is no exaggeration...30 seconds after I got top up and locked into place the skies opened up...going to let car sit for awhile wait for rain to stop and try it all over again and see if it still works..
