Old May 23, 2014 | 09:25 PM
JEFASOLD's Avatar
JEFASOLD
Default Re: clicking in the rear end
Originally Posted by austinbarrylee
Well in the beginning stock rims wasn't click when driving the car for awhile. Once I put aftermarket wheels and tightened them the clicking noise started. So I took off the aftermarket wheels and put stock wheels back on the clicking noise continued but not as loud. Thanks for help.
Did you use new bolts with aftermarket wheels? If so, did you use the same bolts when you went back to stock? Grind 3/16 inch off the bolts and you should be good. Also make sure you have the correct bolt seating shape for your wheels. There is conical and ball types.
