Old May 23, 2014 | 09:38 PM
austinbarrylee's Avatar
austinbarrylee
Default Re: clicking in the rear end
Originally Posted by JEFASOLD
Did you use new bolts with aftermarket wheels? If so, did you use the same bolts when you went back to stock? Grind 3/16 inch off the bolts and you should be good. Also make sure you have the correct bolt seating shape for your wheels. There is conical and ball types.
I am using stock bolts. like I said there was no noise. As soon as I put the aftermarket wheels which are Mandrus Milleniums on the noise started. Continued after I put the stocks wheels can back on.
